Decided to do some upgrades… the RacerStar are great motors for the price and do have good power but @okp did some great custom mounts for evolve trucks that allow you to fit 63mm motors so I just had to give them a go.
So a marriage between @okp UniK mounts and eskating.eu 6355s 190kv 3510W motors just happened:
Anyhow, it’s time to do some motor configuration and detection. I still won’t be able to test the new setup due to needing longer belts so I’m currently waiting for a few that should be here next week.
I also got some 36T pulleys from @johnny_261, 15/32T was working fine on my old 140kv motors but for the new 190kv it’s just too fast. Specially on 107s the calculator shows 34mph… I really don’t wanna try that.
New specs with the upgraded motors should be:
Street setup with
Abec 107s on 15/36T pulleys: 30mph top speed
Street setup with Abec 97s on 15/36T pulleys: 27.5mph top speed
AT setup with Evolve tyres on 15/66T pulleys: 27mph top speed
Awesome build!
Pleasure meeting and riding with you and the guys/gals on Saturday. Thanks for letting me borrow your power bank for a bit, looks like my issue could be a motor phase wire break though not so much remote battery.
Had the motor apart last night and it seems fine, so I think it’s the other end leading to the ESC. Fingers crossed I can get it done by Friday for Critical Mass.
Whats the lenght on your enclosure? (never mind found it in your part list, shame on me)
How big enclosure could you fit on there? How long is the part where a enclosure can be fitted?
@egzplicit I have put together a similar build using dual 6374 motors on the unik evolve mount. My street setup works well. However, the stock 360mm belt for the evolve AT setup won’t fit, its too tight. The original evolve motor pulley is much smaller than the normal keyway pulley that I can see you are using as well.
How are you running your AT setup? Did you have to but a longer belt?
I was thinking I’d go up to a 365mm or 370mm belt but I cant find anyone that sells one.
