It is my second build with this deck already. I sold the first one but I missed this deck, so there for another build. This is my current progress:
The pulley:
As there is no pulley on the market for the Venom Mach 1 Cannibal wheels I decided to make my own ones. As the holes are very thin I went for a version with a bearing inside the pulley. It uses a normal 608 bearing. I have to test if the adapter flanks will be strong enough. If not I’ll make them with small M2.5 screws wich will stick out of the pulley body. Here is the result:
The fit is perfect. I designed the pulley that 3 washers take place between the pulley and the wheel bearings. I chose 32T because of the small diameter of the wheels.
The deck:
As I said I really love this deck. I took this from a scrapped longboard. I will sand and paint it completely but just after all holes for the inserts and stuff are done. Color will be something like the griptape. I had to cut the back of a little, so that the motors fit.
The enclosures:
I designed the enclosures myself so that they hold the batteries I want at a small outer size. Also I want to upgrade the battery of my Foosted build to 12S. The goal is to use the battery on both boards. Also I’m not 100% sure about the battery yet. I’m going for VTC6 in first place but might also make one from two 6200 mAh Zippy compact. The case sizes might differ slightly but the mounting pattern will be universal. The battery case will be also closed with a lid and a few screws. Unfortunately I have to print it in two pieces as my printer is not big enough.
The case for the Unity also holds a battery meter. It is designed as small as possible because the deck gets very narrow at the back.
On the deck it looks like this:
The motor mount:
I wanted drop through and a reverse mount because the motors won’t really have enough clearance in the normal position. And I guess it really looks so much cooler with a reverse mount. As for now the plates are solid stainless steel (laser cut). The trucks rings are 3D printed. I’m not sure yet how they will hold up. I plan to make this aluminium later in the process. Also I’m waiting for the cross bars between the plates. So this point is still in progress.
If someone is interested in the pulley or the mount you can write me a dm Making the rings aluminium would be easier if it wouldn’t be just two pieces
Let me know what you think of this build. I’m currently waiting for all the electronic parts but I hope I can finish it in a few weeks. Stay tuned for the updates!
Hey, have same wheels planned for a build. Might be interested in the pulley, after you have tested it. @okp has made an aluminium proto pulley for these wheels too, so keeping my eye out for that when it’s available from him.
Yeah I saw his build log. Was also interested but decided it is cooler to make my own. Also I’m not sure when they will be available and I think as they are cnc’ed they might be quite expensive. Surely better quality…
I’ve already printed mine and the fit is tight. I actually have 31,5 & 26,5 instead of 30,5 & 25,5 for the diameter of the flanks. I will see how they will perform.
ehhe hey folks, sorry for the non reply. I’m chasing time more than ever lately. My kid got chicken pots and I was not vaccinated neither got it when I was young… imagine the mess at home. Was also overloaded at my real work and moved apartment. I should be leveling the bed of the 3D printer and keep moving on this.
It’s a bit frustrating, the build could be already finished but still waiting for Enertions Unity to ship…
So in the meantime I printed the cases and build the battery pack. First version of the battery box looked like this:
I was satisfied as everything worked as planned. But as you might see the case is just way to big for the 12s2p battery. Therefore I made it smaller and somehow managed to get it to print as one piece… pushing the limits of my printer
Result is top! Still have to print the lid, put the thread inserts in, finish the battery, implement the battery in the case and do the postprocessing. I guess I’m going to sand it and give it a clear coat then.
Last day the rods for the mount from my father and the footstop from Roger Bros. arrived.
View from the bottom side with cases:
Finishing everything the next days so that when the Unity is finally in I just have to do the cable management and re-print the Unity case
It’s from aliexpress. I guess it won’t stay grippy for that long (used it before on other boards), but if so, I will apply some glass fritt or spray-on-grip then.
