I want to build a dual motor board, so I will need 2 ESC’s. I also want it to be chargeable through a BMS and therefore one charging plug for a plug-in and forget solution.
I will be using 4 batteries in total. 4x 30C 8000mAh 3S batteries. Two wired together to be 6S, and then I assume each 6S pack has to go to one ESC and one motor. But I want to be able to charge all batteries with one plug.
I have no idea how I’d even begin to wire this. Is it possible to wire one BMS to each 6S battery, and then splitting power from the charger input on the board to each BMS, and using a higher voltage and amperage charger?
Your 2x ESC’s should be hooked up to the battery pack in parallel, so that they see identical voltages and the current is split between the two. Then you only need one BMS and one total battery pack (consisting of multiple batteries)
I would make it one big pack. So if you want a total of 6s, then a 6s2p. So the black and red of the two 6s packs will be connect to each other (a parallel connection) and then you split that to each ESC
you could do 12s if you’d like (all of them end to end) or 6s and have half of them be in parallel (2 sets of 2 end to end, and then 2 sets of those side by side)
No. Maybe it’d be more clear with numbers. For example, if you had a 12S battery pack delivering 60A to two ESC’s in parallel, each ESC would get 12S 30A
Basically I’d be using two motors requiring 6S, two 6S ESC’s and two 6S battery packs.
Do I wire the two battery packs in parallel then? Wouldn’t that simply increase my mAh and not my output amperage?
Basically I need 6S going into each ESC, and each motor needs to be able to draw at least 60A. And all batteries need to be wired so I can charge them through one charging plug into a BMS but I’m so confused as to how it’d all be wired…
Is there any particular reason you want 6S? I’d recommend a higher voltage to reduce your current draw, which decreases the amount of heat generated.
If you put two identical battery packs in parallel, it doubles the capacity (Ah) and also doubles the max current output (A), but the voltage stays the the same.
Side note: If you are only running 6S, you don’t even need a BMS since you could use a 6S balance charger
I specifically want a laptop style charging solution though so a charger like the imax b6 is out of the question.
Only reason I’m so focused on 6S is because with my current board I’m using a 6S ESC and the motor runs fine on 6S, so I thought it’d make everything easier to just stick with that
Here is my wiring diagram, does this look correct?
Also, this is my first time with wiring stuff, what is the best way to make the T junction because it seems like you have to tee off at some point with one branch going to the charger and the other branch going to the vesc.
