Landyachtz Evo Deck Torqueboards mounts Torqueboards Vescs 12s4p battery Dual 6374 motors 12mm belts 107mm Abec 11 Flywheels GT2B remote
it doesn’t need a name dude, but it needs to be ridden!!! go ride it…name the feeling it gives you instead…
Did you pre-chunk the back wheels?
Yup.
First tried a dremel with a metal cutter, sander. Ironically the only thing that ended up working was an exacto knife and about an hour of elbow grease
hahaha definitely. Currently charging up the battery again
Next time just use a file and spin the wheel on a motor, bench grinder, buffer, lathe… Lol Build looks good
Sometimes for rubber if you deep-freeze it first, it can then be machined. I’m not sure if that also applies for polyurethane.
It helps alot.(freezing)
I’ll definitely keep this in mind. Thanks
@Zac13 Sick build man! How much did the finished board weigh? Considering it was dual 6374’s, 12S4P, and 107 wheels.
A little over 30 lbs! I use it to commute into work, and to fly around on, but would not want to carry it anywhere
What gearing are you using? Would you change anything ??
