i was wondering if anyone can recommend 2 5s lipo btteries for under 100 dollars, and that will fit in a 2 inch clearance between my board and the road.
You can put all of your size and output requirements in and it will give you options.
Just bought two of these: Currently working on the build right now, but the thinnest side is 38mm, or 1.5 inches. Around $40 a pop. Hope this helps!
I second those batteries, I have one of them they are great. I accidentally ran one down to like 2v per cell, and successfully revived it. Pretty good batteries for how much they cost. As far as I have looked, that battery actually has practically the highest wh/$ ratio I have found for a hobby lipo
thanks i think i am going to buy those
i have this motor diy-electric-skateboard-kits-parts/electric-skateboard-motor-6355-190kv/ and im buying this esc http://www.ebay.com/itm/302332747417?var=601169319511. can i use everything with these batteries https://hobbyking.com/en_us/turnigy-5000mah-5s-20c-lipo-pack.html.
I’d concerned about that ESC; that ESC says it can handle up to 10S but do you want to risk it? Maybe I’m a pessimist. Anyway, you’ll probably be underpowering your motor (theoretical max) by over 1000W.
Consider spending some more and buying a VESC (available at DIYelectricskateboard and other places). You get what you pay for.
i know but i cant afford it
