I haven’t touched this project in a while and have not only misplaced my manual, but also the picture @longhairedboy sent me.
Long story short, I need to wire up this BMS and am not sure what goes where.
-the e switch is the two prersoldered wires
-the balance leads are already hooked up because I did that when I had a manual…
P- is for negative wire to Esc’s
C- is for negative wire to charge port
B- is for negative wire from battery
The positive wire from battery goes directly to Esc’s positive wire and charge port positive wire.
I just hooked mine up a few days ago and so far it works like a dream.
Note: it won’t even turn on unless you have the balance wires connected
I don’t think it matters which you connect first. Just have all the wires connected correctly when you turn the bms on.
If you have the balance wires connected in the wrong order, That will damage the bms.
On my very first build with Li-ions and bms, I connected the main wires first and tried to turn the bms on without connecting the balance wires. ( How Dumb Was That)
The bms would not turn on. ( obviously because it saw zero voltage from all cells) So I connected the balance wires and then it turned on and the whole episode did not damage the bms.
@Namasaki what’s preferable if i want to use BMS for charge and discharge (no bypass!)…to have a BMS with the same port for charge/discharge or with different ports?
What’s the difference and impact on the the design to have one or another (if any)?
I don’t know if it makes much difference whether there is a separate charge port or not.
I’m not an electronic engineer though so I can’t really say for sure.
I prefer the Bestech bms mainly because of other reasons.
It’s ability to handle high peak amperage.
The heat sinks
Twice the balancing current of other bms’s
And most of all, the built in E-switch which saves you from spending an additional $40-$60 for an external E-switch that would likely fail.
