When you get around to it could you post a range test with that set up as well as your test rider weight. I’m still toying around with 10S-12S multi phase power pack. Just hope to keep it all under 10kg so it is a realistic commuter board.
Yeah. It will be a little while though. I’m awaiting knee surgery.
Been there. Get well soon, hopefully you will have a hot physical therapist. LOL
I made a partition for my VESC’s out of ABS scrap that I had. Should keep everything separate and safe.
Finally got some time to mess around with my vesc’s today. Everything is working! I ran the FOC tests and made some small adjustments. VERY PLEASED!
Cant wait to put some miles on this rig! Woot!
What are the dimensions of the 10s4p battery? Do you have a low profile enclosure like the one for space cell for it? Thinking of upgrading and using spacecell on a single drive board.
My 10s4p does fit in the Low pro enclosure. you would need to use split 21" version though to accomodate the vesc. -On a side note, if you didn’t want the enclosure that long it could be trimmed at the seam to make it shorter.
I used my Split sym enclosure which is 19.5" long and a little deeper than the low pro. The reason is I stacked my vesc’s side by side on top of my battery.
I barely fit the spacecell and 2 vesc in the 21 inch… but i guess the bms isnt in the packaging so it may be about the same size.
How are you powering your voltmeter ?
It’s wired to the positive and negative of my loop key switch
I have bought a Drok Voltmeter,it need 3-30 volts to power it , but can measure from 0-100V ,so i need to get power elsewhere than directly from the battery. Is’nt there a 5 v out on the vesc ?
Have you considered using a pocket hole jig for drilling clean low angle holes. I have one and it’s amazing. Requires a step drill bit.
I will have to check one out!
I would turn the motor mounts so they face inward on the board. Then the motors would be under your sweet deck, and may be more protected while giving your board a more sleek look.
All builds are different. You’ll eventually notice I have many and that I made those parts, and know that they can mount that way, and didn’t do that because it’s a drop deck, mounted drop through, with 63mm motors. Lol
