I bought the charging port from my electric scooter (xiaomi m365, see picture) because I would like to use it on a new esk8 build, so that I can use the scooter’s power supply to charge a 10s4p battery pack that I will spot welder. The power supply can output 1.7A at 42V DC.
I noticed the wires are quite thin (written on it: 105 °C, 30 V). I was planning to use the Bestech HCX-D223V1 BMS. You think it’s ok to use or do you think thicker wires are better?
At 1.7 amps, they should be fine. I am using two wires in parallel of 20 awg for 4 amps to ensure they don’t heat up at all. Using a GX12 4 pin plug for charging.
If you have spare wire around, a single 22 awg would be the right specifications for under 2 amps.
That will be fine on 1.7amp, I use a 4amp 12s with the same size and its fine. Charge it outside of the board first if you’re worried. I always do that as a matter of course to be safe.
heres my 2 cents since i got smart with silicone wire and all that… (rough numbers) 22awg is rated at 8amps iirc, 20awg is 12amps which would be the better choice or at least doubling up the 22awg, a jst connector is rated at 5amps before it gets hot and pushing its limits…
with all that said, and now cuz i have an 8amp fast charger for my board im rolling with my 20awg charge wires and just upgrading the connection from charge port to battery wire w/ 3.5mm bullet connectors supposedly good for 20amps… and will fit thru the charge port nut. =)
