These cells are rated at 10a each but mooch says that there is some sag on 10A and he recommends it on 7a per cell which is still 63a cont and probably 120a burst when needed/if needed. (im around 115kg with the deck)
Im building a trampa for the streets/ light cursing no mtb as im too lazy and that seems exhausting
This should give me a nice 1100wh so no worries about how much juice i got left
Do you guys have any reason not to make a battery with these cells?
They are on ES for 3.6$ each so this is 360$, a steal!
If I were going to get a load of cheaper, lower-discharge cells than the 30Q but still with a decent capacity, would be wrong to overlook the humble PF
Im planning on buying the cells from EndlessSphere 3.6$ each
These PF cost 3.15$ each i think these 45cents per each are worth the extra $
29ah for 361 (sanyo)
26 For 311$
And I also readed somewhere that those PF have high IR and sag a lot
they are less then 35 mohm so at 8 in parallel its like 5 mohm which is lovely les than a 4p12s q30 pack witch is like 6,5
i also ordert a few 26650 liitokala cells of china they say they are 20a discharge 5000mah and 26 mohm for 4 euro a piece !!! so it seems to good to be true so i ordert 4 and some 1 ohm resistors so i am gone put them true some heavy cycels and she if they can be a candidate
I have these cells in a 10s4p config. Great for cruising and have no prob reaching speed and climbing hills. Has a pretty decent tourque but some expected sag being lighter in the discharge dept. But 9p you would love these cells.
Yes mono drive 6374 190kv. 16/36 gearing. In BLDC mode got it up to 42km/hr and about 39km/hr in FOC. If you have hills to climb, get batteries with a higher discharge (unless you go with lots of parallel groups) but on flats I’m very happy with these cells. Good safe chemistry as well apparently.
