I just need to make sure I got this right before doing anything at all. Almost ready to start a build thread, just need to wait for Torqueboard’s 218mm Calibers and the two VESC to arrive.
This is what I think needs to be done to make 12s4p.
The part that I need checked is for Balancing Board/Equilibrium Module via the banana plugs because each lipo pack contains two series and I will need to connect two of it to form 4 parallel.
Wouldn’t just connecting the two blue balance leads from the parallels together to form a single blue balance lead and then just leading it to the correct balancing pin work fine? Obviously need a ground from the first pack. All other grounds not needed.
I just realized that I could fit 12 2s2p onto my board allowing me to keep the same 15,000mah as 60 30Q cells in 12s5p configuration, but with 180C therefore greatly reducing voltage sag.
Dimensions would be L 41.55cm x W 18.6cm x H 2.5cm
I will be using Cycle Satiator 48V 8A of which I have already ordered and is also waiting for it.
The reason why I’m not going to use BMS is to save space and will be using Ollinboard’s fuse/antispark.
Another reason is I wish to stop charging at 4.1 volt for longer battery life and to allow headroom for voltage surge/overcharge from regenerative brakes if I start atop of a hill one day when the board is hot off the charger.
I will cap Amax at 80amps though and redo the wires with 8AWG Red and Black.
What do you mean re-think my wiring, where is it wrong unless you mean too thin wires?
You could save a lot of money by using the Bestech 12s bms with built in E-switch and you could use a lab power supply to charge to what ever voltage you desire.
I have gone down steep hills with a full 10s battery and the bms keeps regen from over charging the battery and I have had no problem with any thing shutting off.
A stand alone E-switch takes up some room and requires additional high amp connections.
I do not think the range is extreme, only 52kms. Here is my calculation. (I set watts per km at 11 as that would be average normal use, screw ECO mode)
I see that the watts for each motor may be a bit high which is why I might have to lower Amax to 60amps.
I know Evolve GT has two motors combined for 3,000 watts but I do not believe that the garbage battery pack they use is capable of feeding that much, probably peaks at 1,800 watts combined.
The balance wires are incorrect now. you’ve taken the pack that are in series and put their balance wires in parallel.
Plus it will be easier to do this system with a bms that will monitor each cell group individually if you make 6 groups of 2 packs in parallel and them put the 6 groups in series.
Not going to buy the batteries as of yet, still need to wait for the two VESC so I can lay it on my board and eyeball the remaining space instead of just trying to imagine it all.
I’m a bit apprenshive about this BMS. A bit odd that I would need to leave the board on to charge it up? Also, I read this thread.
With the e-bike charger, at least I will not have to buy another charger for different configs in the future as I can adjust it from 24v to 52v and charge from 1amps to 8amps, so still ok with the somewhat expensive purchase.
I forgot to mention another advantage of longer mileage which is fewer cycles in the same amount of time, meaning the pack will last longer before hitting 80% capacity.
Battery enclosure length would not be much of a problem, but the width is impossible.
I have gone Li-Ion 12s5p. Two 5p in parallel side by side is 18.5cm which can fit and have both terminals on the same side instead of one near the BMS and the other at the other end of the pack.
