Couple of charges on it and recently repaired, I did a full diagnostic check on it too. Its ready to go unless you want a different bms, switch is included
Re-upload the pic pls. You hit reply button to quick there
double layer nickel and copper
1 layer of nickel and copper each or two layers each (4 total)?
Or is it 2 nickel and 1 copper? Hmm
it’s 2 layers nickel with some .2mm copper reinforcement on the series
guys @barajabali / Chiboards makes AWESOME batteries. I’ve traveled to 3 countries with a 10s4p battery he made me. I ride 10+ miles a days for almost an entire year now and it STILL hasn’t let me down.
Heyoooo
real men ride pink !
Yes this comes with a bad, charger, switch and voltage display
Price drop $500 plus shipping
Drop offers?
Overall pack charges (if known)and what was repaired.
about 15 cycles but never full discharge so maybe 10ish full cycles? 3 damaged cells were the issue however another had an issue with fishpaper on top so that was also replaced. All removed cells were replaced with brand new samsung 30q cells
How did the cells get damaged?
Where are you traveling to/from that you can carry a pack that big?
This pack is priced right. Stacked batteries are for sure more work to build.
Esk8 accident 2 had dents, I can show u pictures of those, and 1 had a slight dent but don’t want to take the risk, and
It’s a very good battery and the only reason I’m selling is because I don’t have a build that would need such a large battery, but anyone looking for a relatively compact high power battery then this is it, not to mention nearly no voltage sag if any. This is smaller length wise than a spacecell and only 14ish mm taller than a single cell flat pack
