So im starting to build my battery pack, gonna use Samsung 30Q cells (48 of them). I’m making this post to get some more info/tips of other people who have build some. I already got my parallel packs glued with hot glue, but maybe need to reinforce it more? More glue or silicone maybe?
Also gonna wrap the positive side with fishpaper and then glue the PCB on (Hot glue or silicone?)
And for my 12S layout i was thinking this would be the best for my deck. Whit tape is copper flex wire and the + and - terminal are on the right. (placement for the pack will be more to the front, unity and BMS will be in the back.
So if anyone have some pics/info would help allot! Wanna make sure the pack will be good build.
@AlanZhou, in his defense, on the positive end, you could have part of the adjacent negative can slide out and get crushed into the positive top, but If youre pack has shifted this much, you board has had a real bad day.
