So im in the process of building my first electric board and was curious about a few things. what kind of range and speed should i expect with a 12s4p and a single 190kv 6374 (16/36 gearing) on 83mm wheels?
Also i weigh 130lbs. i know there isnt an exact number but im just wondering what i should expect.
Because you weigh less than me (I weigh 160) and because you only have 1 motor I think 12s4p would probably be fine. Why do you need the range? I think it should be plenty in most cases, especially if you have a fast charger.
I dont absolutely need that much range i just want the ability to go far if want to lol. im probably overthinking it, i’ll prob just get the 12s4p, like you say it should be more than enough.
I definitely will, i have a skate shop like 10 miles away so if i go up in that area they’ll most likely let me charge up while im there so i can safely make it back home. and a fast charger would be a must for that.
how long would it take to charge a 12s4p from 30%-40% to 100% tho?
if you get that cheap 10$ 2a charger it charger 2amps per hour, if you get a 3a charger it charges 3a per hour, and so on.
devide your battery Ah with charging amps and you will get the time from 0-100%
