Hi all ! Im making this mounts to be affordable to everyone .
Short story: I wanted to build DIY esk8 and i could not find any cheap options for motor mounts in EU…
This design allows this mount to be rotated and flipped in any direction you want and is reverse mountable. It can ba used with 15mm and 12mm whell pulleys .
Two different pieces, for 50mm or 63mm motors.
Some specs:
Clamp thickkness: 10mm (aluminium)
Arm thickness: 5mm (steel)
Center to center distace from around 71mm to 80mm
Weight: 63mm (~200g) , 50mm (~185g)
Recomanded belts: 265-295mm - (It depends on what size of wheel pulley you will use)
So the mount is s355 and not aluminium right?.
Have you checked the straightness of the mount? Usually steel flat bar differs quite a lot so it can be hard/impossible to get it lined up correctly
What is the center-to-center distance between the wheel axle and the motor axle? Some range like 70mm to 95mm or whatever is what I’m asking. (those are example numbers only) I like the closed-end one better
Have you considered a series of round holes instead of oval holes around the hanger? That way it’s adjustable (though not as much) but once you set it, it’s impossible for it to move on you
You can sell things if they are in-stock as a Level 2 but to take preorders or group buys the rules say you have to be Level 3 or have someone that is organize it for you
I prefer the open end. Makes it easier for me to remove a pulley from the motor if the setscrew gets damaged. I can simply slide the motor out and it gives me more room to work with.
Also, when doing a dual drive build with limited motor space, it’s easier to mount the 2nd motor by sliding it in after attaching the mount to the truck, instead of attaching the motor to the mount first.
You can sell items you have on hand ready to ship but must be trust level 3 in order to do group buys, sorry for the inconvenience but this is only to keep our members safe.
