Anyone have a 16T 15mm wide 5m HTD motor pulley with a 8mm bore they would be willing to sell me? Or a recommended place to get one?
I was planning on using the one from the brushed motor from my donor zboard but the bore is bigger than 8mm, possibly 10 or 12mm so it wont work
Thanks. ill give that a try
if you’re good with a drill you could buy a 16T 6mm bore pulley and drill it up to 8mm
i might still try that will the pulley i have, as the drive shaft is stuck in there super tight so i could bore that out.
I tried doing that on a cheap drill press and ended up with a super wobbly ass bore. Things I need
MILL
Lathe
Vacuum forming machine
Spot welder
The world
The universe
Don’t know if you did this, but for a more precision hole you should drill under size then use a reamer to finish the hole.
If you already have a hole close to 8mm, then just use reamers. A good set of reamers won’t be cheap though.
http://www.amazon.com/Accusize-Metric-mm-13-0-Chucking-5500-SB00/dp/B00RW6ZN66/ref=sr_1_1?s=industrial&ie=UTF8&qid=1464483797&sr=1-1&keywords=reamer+set+metric
