I’d say 30q but I’ve basically completed my board and have ridden it a couple times but I feel like I’m not getting the range I want. I’m using samsung 30q batteries in 10s2p and am getting around an estimated 6km max? That just doesn’t seem right to me. According to the battery module I use I cannot charge the board past 87% which might be the start of the problem. If anyone has any idea on what to do to fix this or any ideas whatsoever please let me know
not charging past 87 sounds like a bms issue… could be a charger issue but less likely… a few of my packs all tend to stop at 99% (as per my LCD meter), u should get like 16km max on agressive riding if my math is right
So the 30q just come out better in the bench tests bassicly correct?
And 90% are using them
Was just worried that the 6384s 4000wat wpuld be to much for the 30q as i have 0 experience with them
I had this exact same issue the case was not all the bms wires were fully plugged in and also was caused because was not using a charger made for that voltage
Ask yourself if your controllers can handle more…
Now a days I see everybody going bigger and bigger…
For sure it’s nice to have big motors, but honestly, I guess most even can’t use 70% of the capability of there motors.
If there is a bottle neck somewhere you can’t get full performance.
So let’s look on the 6384 4000w motors
You run 12s, means 4000w/44,4v=90A
Don’t know which esc you use but for this you need one able to handle 90a constant.
90a constant for single motor, 180a for dual…
So to get the power you could get out of your board you need a battery, able to deliver 180a constant…
Sorry to say but a 12s4p is far away from this.
Even with a pack of VTC5A and 35A it’s still not enough
I got mine from imr battery (I’m 90% sure they are legit Haven’t seen anything wrong but you never know). The company was really good with shipping as I live in Canada and included casings made of plastic and cardboard. eBay has some I believe on mass sale so 50 or 100 lots. Just make sure they are a trusted seller
Worth every penny there are more features then are mentioned in the description E-switch wireless switching tracking over time. i haven’t been using them for crazy long but i have 3 and 0 issues with any of them as far as i know.
