so, new day new problem.
some time ago I bought a semi-functioning “complete” from someone on this forum that lives (lived?) in Milano like me.
I have a 245kv turnigy motor, a esk8.de vesc and I can’t do a motor detection
The motor stutters and tries to spin, but bad detection results are the only thing that comes up. I tried with two different computers, with fw 2.18 in bldc tool (reflashed also), then I tried with 3.xx and vesc tool flashing a bootloader and the new fw.
The voltages for cutoff ecc. are ok for my 8s, motor A, bat A, regen… all seems to be ok, but detection fails every time. I tried to play with the parameters in detect mode going from 1A all the way to 12A and with min. erpm and duty cycles changing them in increments, but nothing worked… other things to try?
note that the motor was sorta spinning before, but if I gave him full throttle suddenly the vesc would reboot, so I had to do something to ensure it would work better than that… but now it does not work at all!
try to increase Duty to 0.15 instead of 0.05 when you do detection. Btw Battery Regen is extremly low at -40. What Battery do you have? And lower max erpm to 60000 and -60000
i run two 4s lipos in series with a bypassed bms for charge only. batt. regen is default now, what should I put there? I don’t rely that much on batt. regen
well battery regen is important for breaking. depending on your battery capacity and max charge rate you will have to lower or increase that value, because if you feed to much back into the battery it can take damage and damaged batteries are dangerous
I didn’t dig that much into battery regen for the moment, as I can’t get the motor to spin at all
The battery is a 8s 5200mAh 35c, what could be a good parameter for batt regen in this case?
35c is the discharge, i am guessing it is 2C max charge current, so 10.4 amp charge and you can safely add a bit to that. so -13/-14 amps battery regen. But try increasing the duty on detection for the motor.
so, after a good 4 hours of beauty sleep I’m here at work wondering why I didn’t pull out a multimeter and checked the internale resistance of the motor phases.
I’ll do as soon as I get back home, but my idea is that whoever did the soldering job to put silicon 10awg wire on the phases did a bad job and something is shorting out.
BUT I checked the motor before trying to detect it and it seemed to spin freely, so I’m not really sure whether or not this is the case.
in theory if I disconnect the motor and spin it it should spin freely, but shorting two phases together (or all three of them) should result in some resistance in the spin, right? I’ll also check if there is continuity on every wire coming off the vesc to the motor to check if I fudged up somewhere and have a bad connection from vesc to motor.
I’m pretty sure the problem is at hardware level because of the “no fault” thing.
It was indeed a good idea. One of the phase wires had a bad soldering job.
In fact all three had one bad solder blob on them, but one was cracked and was my problem.
The job was done by a monkey with two left hands and the phase wires were cut very close to the can of the motor, so it was very hard to resolder, but I eventually did it.
The motor could finally run detection no problem (and I changed my regen to -13).
On the next topic: I jumped on the board to try it and brakes are very weak. I assume I have to change motor current max brake to enhance their performance? more amps=more brakes? I’ve put a conservative 50A max motor current and -50A on brake current (stock was 60A; -60A)… how does it work exactly?
as it was explained to me. Battery regen is mostly effective while braking at higher speeds, and motor brake current is for lower speeds. But yes ofc, since you lowered the amount of amps you can put back into the battery the force of your brakes is weaker. I think you could go even higher than that on regen since it is mostly only for a short time. Thas why most build dual drive with vesc or a bigger mAh Battery.
My old build had a APS ESC and that thing could brake like an anchor, but shit at smooth acceleration or controling my battery.
I don’t trust my battery enough to give her too many Amps more than she asks.
I’ll try to go a little higher with max brake Amps and test. Tomorrow. Tonight I’ll enjoy the feeling of a solved problem and cheer with a scotch whisky to your kindness and to all the good stuff we can find on this freakin forum
yeah i did phasewires myself on my sk3 and they also look horrible but resistance was ok, but the flex is realy superior to those hard wires that come with the motor.
