Looking to buy some belts in the us
Specifically at : http://www.vbeltsupply.com/
If you are looking for 5mm pitch and 9mm wide Heres more specific :http://www.vbeltsupply.com/265-5m-09-synchronous-timing-belt.html
Not yet kinda wanted to just buy from someone on the forum
I have 3 extra 9mm 265 Brand new from APS
How much for a single or all 3
Would you mind some 11mm 5M HTD280?
I do have more 265’s in 9mm wide. Send me a pm
hmm after like an hour of researching and using the belt length calc im thinking now i need something like:
Tooth Style (Pitch) HTD 5mm Number of Teeth - Large Pulley (A) 60 Number of Teeth - Small Pulley (B) 20 Belt Width (mm) 15 Desired Center Distance 80(mm)
Attribute Value Speed Ratio 0.33 Pitch Diameter - Large Pulley (A) (mm) 95.5 Pitch Diameter - Small Pulley (B) (mm) 31.8 Desired Belt Pitch Length (mm) 372.8 Next Available Belt Pitch Length (mm) 375 Next Available Number of Teeth - Belt 75 Center Distance Using Next Available Belt (mm) 81.3 Teeth in Mesh 7
I think you are using 3M because a 60T 5M pulley is bigger than the wheel… I do have 3M counter parts too.
lol my eyes hurt from staring at a screen and it was right in front of my face. yeah it is 3M im using. the htd 255-3M is just a little too short
