For the trucks I am curently using I need 6355
Might switch up trucks though
Can y send link
Edit:going to have to buy larger trucks anyone got a god idea
Can y send link
Also anyone know where to buy protective gear
Google search
12s 5p and 192 motors. 97mm wheels and 15/36 gearing, 35 is a breeze. Just go do it sunshine.
Thanks mate what about the same as you but with 14:34 gearing
Put it this way. I can go over 40mph with my set up and yours is no different. 15/36 and 14/34 is not a big enough difference. Are you sure you want to go 40 plus? Its a different ball game at those speeds. Trust me.
No just need t reach 35
Thanks to everyone for the help will upload more pictures soon
Ordered 2 flipsky 6355 190kv motors
Are they any good
So I am now up to the stage of thinking about an enclosure what are my options about buying one for under $100 which will fit the following dimensions if anyone knows anyone who will do one preferably in the Eu please say
Here are dimension 40cm long…16cm wide…4cm high
IKEA Stödja
Yes I thought of that but isn’t it cheap quality and going to break easily
What about using a wooden enclosure built by myself
If yes how do I waterproof it
There like 1 Dollie and it’s flexible as hell, you could always buy multiple ones
Is here anyway to strengthen it up and how do you screw it down to the board
Kydex
How do you press the keyed down
Kydex
No keyed
With your hands or a negative of your mold
As in don’t you need a vacuum press or heat press
