The NEW Enertion S.P.A.C.E Cell Electric Skateboard battery is the thinnest & most powerful battery on the market to date
IN STOCK NOW | FREE WORLD WIDE DELIVERY $310 USD
*United States Dollars is based at conversion rate 23/07/2015 from $415AUD to USD
CLICK HERE >> BUY NOW
SMART-CHARGING | POWERFULL | AERODYNAMIC | COMPACT | ENERGY-CELL
http://youtu.be/1j4CfCSz0fgCOST COMPARISON LIPO vs SPACE CELL
Building your own electric skateboard has never been easier.
This is more than just a battery, the Enertion S.P.A.C.E CELL is an all-in-one integrated solution for DIY builders.
This product has built-in Voltage Dispaly, Built-in On / Off switch, Built-in Easy Charge port, Built-in Battery Managment System.
The pack has a massive 270Wh of power which will offer approximatley 1.5hrs run time on a dual motor eboard.
> BMS is rated to peak output of 60AMP which is ample for use on electric skateboards. This pack is for motors of 2400W or less.
> The Charge time is 3-4 hours & the charger is light & compact so easy to carry.
> The battery is 10S3P meaning it has a total of 30 Cells, 3 Parallel groups of 10 cells in series.
> Battery Chemistry is Li-ion NMC
> The Pack is 270Wh based on 36V nominal voltage. Approximately 1.5hrs run time on Dual motor Eboard.
> Total weight is only 1.8kg
> Dimension of 380mm X 140mm X 23mm
> Mains fast charger is 100-240v compatible & outputs 42v at 2A.
BUY ELECTRIC SKATEBOARD BATTERY ONLINE
