No, the temperature haha
Yep. Just a coat of glue stick on the bed
Lol, confused the hell out of me
Keep your fingers crossed, but I raised the temps to 210/70 and seems to be printing fairly accurately. So what are the recommended temps for ABS?
240-260 for ABS. 70-80 print bed
You also need ABS slurry for it to stick properly to the bed. I donāt use ABS any more, and have moved to using Algix Omni.
Iāll give it a shot, thanks
ABS Slurryā¦That sounds aweful. I wonder if mine print Algix Omni. Time to google
Up to this point Iāve printed wheel pulleys and retainer caps, GoPro mounts, pretty much anything within 75mm width and length. If I try to print anything big, 100mm or larger, the endges curl and the ends of the print seem to āslideā. Is there a common reason why this happens? Some setting(s) I could adjust and test?
I got pissed and threw all the bad prints away, or Iād post pics. If it helps I do another tonight and post pics.
Thanks for the help.
