would love to know how these hubs and gummies compare to ABEC 107s on rough roads
Thats 100% gummie U can see wheel hub spinning nicely
Nice ethel ! Thanks for sharing the setup !!
So it is the only way to get those wheels … Anyway, I like it !! Now I take time to looks them in every detail, they’re gorgeous. And your build too, good ride
What do you mean?
Just that is exclusive with the complete kit, for 218mm TB truck. 3DS propose almost same set I think : But it is not the exact same the exclusive one for TB 218 and your geared drive : https://cdn.shopify.com/s/files/1/2408/6975/products/IMG_0478_600x.jpg?v=1536245361 But maybe I’m wrong.
I really need those kinds of good stuff ! The hub adapter I have to mount the Superstar hub on the Supercarve truck is really … weird (to not say bad)… Bud before any upgrade for those hubs, I’m just waiting to see what Haggyboard will propose (if I could go with 150/125mm wheel for my urban build). Anyway, can not wait to see the GB for the 9" hubs
We already sell them separately
ok ! They’re the same !! …That is too bad for my wallet I 1st need to see HM will cost the 9" and then if I could add this 200€ to get both … Did you know witch bearing are used with the option? I heard they are hard to set without a press? http://img.medicalexpo.fr/images_me/photo-mg/74048-9538998.jpg
Look at that gap between the hub adaptor and the bearing on my poor setup… Plus the driver roll like a snake
What size are those motors? I was thinking of doing something similar to this using parts I had lying around. A potential problem I have are the motors I’m planning to use: sk3 6374 which aren’t “true” 6374 because of the nipple.
TB 6374 motors. Think sk3 are slightly bigger. From the picture there looks like space.
Correction: I don’t believe sk3 6374 will fit space. Measured space between 3DS enclosures at 173mm and I believe 2x sk3 6374 motors are 174mm
If two sk3 are 174 then I believe you could just put one speed ring on each axle before installing the drives.
I do not think that will work as 3DS gear drive is a hub sleeve.
Exactly, if you put on a speed ring or two first it will force the drive out slightly giving you more space between the two drives.
Or you can grab either Fatboy 230/240 hanger
Thank makes a lot sense. Good option if you have sk3
I ordered 240 but received 230
Shorting it out Probably by mistake swapped with wrong order
I need to adjust the bushing and truck setup riptide 96a doesn’t turn for me. Need to add thicker grease to the gear drive and then I am taking this out with the group ride in SF city where the roads are shiit
I found better grease for the gear drive. I cleaned the old spray grease and applied liberally. The sound it makes is similar to a belt drive train, not too loud.
I changed my bushing to 90a and took off a riser. That was a mistake lol. I had major wheel bite. I had to end group ride early.
@3DServisas @Kug3lis how much would replacement spur gears cost for the FB 1:3 TB gear drives?
