I purchased and received an absolutely beautiful VESC from @chaka. It came with nunchucky adapter and JST connector. Tried that but got intermittent drop outs (only when riding, never on bench).
Tried to solder JST directly to nyko dongle but still had dropouts. Finally, soldered directly onto VESC pads but still getting dropouts!
Any possible solution other than switching to gt2b?
I’m using the Kama Nunchuk on 4 different boards with VESCs (V4.7 & 4.10) and never had any dropouts. All of them are soldered to a JST connector plugged into the VESC.
Did you check if the receiver is placed well for connection and if the Kama transmitter is really stable? They tend to vary in quality.
Also, when using the beercan board (aluminum deck) I placed (and sealed) the Kama receiver at the outside of the electronics box just in case that the deck could prevent proper connection.
knock on wood, but I think I solved my disconnect issue by powering the nyko wireless dongle with 5v rather than 3.3v - the arduino guys using the nunchuck seems to be using it without issues for awhile @5v without issues… will test more and hope the thing doesn’t fry when I’m going at high speeds!
I placed it at the edge of the board because of the massive aluminum deck. It’s more a precaution then a need I guess. But I don’t know how those different makes of the Kama receiver behave, I’ve connected mine with 3.3V though.
well, I replaced the nunchuck dongle with another nyko kama dongle and it works with no dropouts… looks like some of these dongles aren’t as robust as others…
@tomtnt@elkick@lowGuido Has anyone tried using a ferrite ring on the wires between the Nyko Kama receiver and the JST connector plugged into VESC help prevent interference? I’ve wondered if that might help reduce dropouts. It’s hard to figure out whether they are caused by a physical disconnection or radio interference.
that’s a good point - I’m just going to wait for enertion to release the Vedder/Jaccoby nunchuck transmitter/receiver. I don’t trust the current nunchuck. I tried using the big GT2b but, damn, that thing is huge and looks really out of place
I have used the ferrite ring but no difference, no dropouts for months on none of the boards. Beside soldering carefully I only used some hot glue to keep the JST plug in place on the VESCs and made sure that the wires to the Kama receiver do not cross the motor wires.
