I actually finished this build a couple fo days ago, but had some issues. Here it is up and running.
BOARD Moose Longboard 9.5" x 41" Top-Ply Bamboo Deck With Grit $38.95 + Free S&H http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=371761621999&rmvSB=true
180mm Reverse Kingpin Black Trucks $37.99 + Free S&H
FlyWheels 83mm White Longboard Wheels $0.00 + Free S&H (included in trucks order)
Pig 1/2" 0.5" Skateboard Longboard Riser Pad x2 Black $4.99 + Free S&H http://www.ebay.com/itm/131863443263?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
ELECTRICAL Elephant EL008 Compact Waterproof case (Interior Dimensions: 8.25" x 5.50" x 1.75" (LxWxH) ) $29.97 + Free S&H
ZIPPY Flightmax 5000mAh 3S1P 30C (AR Warehouse) $30.22 + $10.93 S&H http://www.hobbyking.com/hobbyking/store/__8587__ZIPPY_Flightmax_5000mAh_3S1P_30C.html
Castle Creations Mamba Monster 2 1:8-Scale 25V $116.47 + Free S&H https://www.amazon.com/gp/product/B00AQYMMHO/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
DROKDC8-63V Volt Meter $12.68 + Free S&H https://www.amazon.com/gp/product/B00VUUKIMY/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
InstallGear 100 Amp Manual Reset Circuit Breaker $10.45 + Free S&H https://www.amazon.com/gp/product/B01HDX3YXG/ref=oh_aui_detailpage_o09_s01?ie=UTF8&psc=1
Electric Skateboard Motor 6355 190KV $90.00 + Free S&H diy-electric-skateboard-kits-parts/electric-skateboard-motor-6355-190kv/
Motor Mount - copied Chinese Motor Mount, machined by me, Converted 5055 mount $10.00 + Free S&H http://www.ebay.com/itm/DIY-electic-skateboard-kit-parts-pulleys-and-motor-mount-for-80MM-wheels-/322242149870?
MECHANICAL 40T ABEC11 Drive Wheel Pulley ONLY $32.99 + $10.00 S&H diy-electric-skateboard-kits-parts/40t-abec11-drive-wheel-pulley/
HTD5M Timing Belt Drive Pulley 15 Teeth 8mm $3.79 + $1.49 S&H
Gates 110XL037 PowerGrip Timing Belt (280mm HTD5 9mm Belt) $6.28 + Free S&H https://www.amazon.com/gp/product/B00CMIHEMU/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
EXTERNALS FlySky FS-GT2B 2.4GHz 3-Channel Transmitter $27.99 + Free S&H https://www.amazon.com/gp/product/B00FS2U9BA/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Master Cho GT2B Electric Skateboard Controller Enclosure $25.00 + $3.40 S&H https://electric-skateboard.market/product/gt2b-electric-skateboard-controller-housingcase-enclosure/
IMAX B6 50W 5A Charger/Discharger 1-6 Cells (GENUINE) (AR Warehouse) $28.41 + $10.93 S&H http://www.hobbyking.com/hobbyking/store/_65166__IMAX_B6_50W_5A_Charger_Discharger_1_6_Cells_GENUINE_AR_Warehouse.html
HobbyKing 105W 15V/7A Switching DC Power Supply (AR Warehouse) $15.05 + $10.93 S&H http://www.hobbyking.com/hobbyking/store/_67099__HobbyKing_105W_15V_7A_Switching_DC_Power_Supply_AR_Warehouse.html
PICS
BUILD PROCESS I mounted the Drok DC8 Volt Meter in the Elephant 008 case using a dremel and the supplied screws. THis may be my favorite mod of an electric skateboard. On the next build I want to build it into the top of the deck for easier reading.
I followed the directions here for the GT2B enclosure mod, pretty simple once I figure out fit. I had to a little dremel work on the enclosure to get the trigger to slide without sticking, but less than an hours work from start to finish.
My motor mount is junk, cheap 5055 aluminum mount from eBay. I am working on a new mount using 6061 aluminum and a mill, will take a little time though as I am still trying to figure out the mill.
I am planning on replacing the trucks as well, just not sure if I want to use Paris V2’s or Caliber II’s. I really like the Paris trucks, used them for years when I skated as a kid. I like the look of the Calibers but Ive never seen a set in real life so I’m still on the fence.
I bought a 9mm belt, shouldn’t have done that, 12mm is much beefier. I’m going to order a couple this weekend.
Overall, I am pleased with this build. It’s much torquier than the 5055 280kv motor I used before, I love the GT2B remote trigger travel, the deck is retro and has a great concave and the length means I can just chill and not worry too much about wobble.
