I am planning on building an 8S lipo battery with 5000mah and 25C. This will be two 4S 5000mah with 25C in series. That should be about 125A output. I am planning on attaching this BMS for both charge and discharge protection. this bms
The BMS supports 45A continuous discharge but my ESC pulls 50A continuous. Will this be safe to use without too much overheating or problems? I live in a hilly area but I heard that a BMS can support 10% more amps than what it has described usually. Is this true?
