I rode around 500km offroad over the summer 2015, when fall came and the days got shorter and darker I had to build a proper headlight. Before I had done some experiments with flashlights but was never satisfied because there was always too much light directly in front of me and always to less light in the far field and in the corners. I found the perfect solution in a 32W (105 lm/W) high power LED strip in combination with a cylindrical lens.
High Power LED Strip: http://www.leds.de/en/LED-strips-modules-oxid-oxid-oxid-oxid-oxid/High-power-LED-strips/SmartArray-L25-150W-25-LEDs-neutral-white.html
Datasheet: http://www.leds.de/out/media/Datenblatt_SmartArray_2014_V11_ENG(3).pdf
LED Strip Optics: http://www.carclo-optics.com/optic-12750-300mm?opticfamily=strip%20optic
This produces a oval shaped spot, wide in horizontal direction and narrow in vertical direction:
The LED strip and the lens are held by a housing stacked out of laser cut aluminium sheets:
The two different parts in 1mm and 3mm thickness are alternating stacked to produce a housing with heatsink fins:
The stack is held together by M4 threaded rods and Locktite:
The LED strip is sitting in a milled slot:
Completed housing with LED, lens and wires:
The spot has some chromatic aberrations but normally you don’t see them, only when pointing on a wall:
The 32W LED puts out a huge amount of light. It is sold to replace a 150W halogen tube:
The LED housing is mounted on the12mm stabilization rods which connect the front motor holding plates:
To power the LED I’m using a Meanwell LDD-1000HW - a current regulated 1000mA 56V step down regulator which is located in my ‘cockpit’ (black brick in the lower left corner of the last pic):
