Hi, Newb here, please excuse some ignorance… Two-3s batteries in series that I’m charging; all cells show on the imax B6 charger, cell 3 and 4 are fluctuating as its charging and I’m not sure why? There doesn’t appear to be any consistency; one second all the cells will show similar voltage, the next cell 3 will show zero and cell 4 maxes out. It’ll show this real quick and then jump back to all 6 showing similar voltage. In regular charge mode the charger usually stops after a few seconds and I assume its because cell 4 hits ~5v(as in the picture) and the summation of all the cells reaches the cutoff V ceiling. In balance mode it usually makes it a little farther along the charge process, though as in the picture, cell 3 is lagging a bit. Has anyone seen this or anything I can do to try and resolve or are these cells cooked somehow? I typically only charge in ‘Balance mode’ thinking that’s the safer approach given the inconsistency.
Batteries = Zippy Capacity: 5000mAh, Voltage: 3S1P / 3 Cell / 11.1v, Discharge: 20C Constant / 30C Burst
