I’m a noob and I would really appreciate if someone could check over my vesc settings. I really don’t want to fry anything when I actually set up the vesc. I tired to provide as much info below about the battery as possible. Anything that I should change? I feel semi-confident that the settings below will work.
6s4p liion battery pack from diy w/ Panasonic NCR18650PF cells Nominal Voltage: 3.6-3.7V
BMS rated for 30A continuous output, 80A peak output The batteries are rated for 10A continuous discharge so 40A total continuous discharge but the BMS can only handle constant 30A.
I have the torqueboards 6355 260kv motor and receiving a focbox in the coming weeks. There aren’t many hills in my area and the black friday deal made the pack and enclosure only $185, so I couldn’t resist as I also have a tight budget.
Current Limits Motor max: 60A Motor min (regen): -40A Bat max: 30A Technically I think I can increase bat max to around 40A or 50A and be under the peak output, but I’m afraid of stressing the bms with too much current… Bat min(regen): -12A Absolute max: 130A Voltage Limits Min input voltage: 8V Max input voltage: 57V Battery cutoff start: 18.6V (3.1V) Battery cutoff end: 17.4 (2.9V, minimum is 2.5V but I want to keep it a little higher)
