Hi all,
I am trying to make a 6s Parallel charge, 12s series discharge circuit.
I am using 1 lipo charger, parallel charging 2 x 6s lipos
I have made up a 6s parallel balance lead, basically 2 x 6s balance leads wired parallel into a male 6s balance lead. I have tested this and it works ok
I am using this picture off the forum as inspiration:
Thanks for the reply mate, I was going to try a bms but I have the charger and the cables so I am going to go with the parallel charging solution for now
Does anybody know if the balance lead can be left connected whilst discharging in series ?
No, the balance leads cannot be connected in parallel, while discharging in series
What you can do is individually wire each balance lead to a 15-pin VGA connector (so, 2x 6S). Leave the connector disconnected while in series (discharge)… The other side of the VGA connector would be wired to put your 6S leads in parallel (2x 6S to 1x 6S). This way you still only have one balance plug to connect AND they are not permanently hooked up in parallel
