97mm wheels on mono raptor
If i change the raptor 1 wheels from 83 to 97mm, will it have any negative effects? Its a single 6374 drive
You will loose some torque but gain a lot of speed.
How much speed are we talking?
Idk, you would have to plug the numbers into this calculator:
www.calc.esk8.it
Hopefully you won’t experience wheelbite… risers could help.
I got two risers on each truck
I swapped to 97mm on a raptor 1 dual drive and experienced no wheel bite but I have stiff bushings/trucks. You definitely lose a lot of torque but with the dual drive it was perfect for me (before it was regularly making me wheelie the board on low speed quick accelerations).
I would just ask yourself if you still have tons of torque climbing hills currently. If yes then go for it, if not 90mm might be more up your alley.
