A few random questions about the vesc from diy skateboards…
what in the heck is the plug on the sensor port?? They wont tell me they just tell me to buy there adapter( 7 bucks. X4) i thought it was a balance tap connector so i grabbed a few and there too big. Any reccommendations?
Top ways of blowing up the vesc to avoid? If i set my max amps to the motor and from the battery correctly. Wont that keep it from every blowing up via hard use?
Is foc SAFE to use now a days WITH SENSORS? I know a while back it was more of a betta thing and blew allot of stuff up… how safe is it to use now a days with a sensored motor? Any special order of setting it up. Or just go to foc calibrate the sensors and whatnot then change a few parameters?
Im using a 12s bms from ebay(from china) when i go to charge the batteries do i need to supply the exact voltage that i want the batteries to charge to or can i go a little over and the bms will chsrge it to the full 4.2v safely? And how much drain will this have on my pack? Do i need to be unhooking it when its unused for a week or month at a time? It was my understanding that it kept the pack balanced 24/7… am i correct?
