Good morning
This is a short summary of the following post: http://dosimplecarbon.com/fitting-bigger-wheels/ Recently, with a lot of help from @Okami, I was thinking about new approach of mounting bigger wheels to esk8. How do you usually mount a 5-6" pneumatic wheel on a regular truck? The standard practice is to use some kind of extension on the axle. This approach increases the loads on the axle beyond the intended values, this is never a good thing. Now, what if we used mechanics and balanced these new loads? Look at the following diagram:
The picture is of a basic model that I used to do a preliminary stress analysis, but the results are very promising, consider these two pictures of stress distribution: The good thing is that you can adjust the offset as you like and the stresses will still be low and actually the truck will suffer much less! I intend to make the brackets from Aluminum, and for now I simply printed them to see the fit:This approach still needs work and several topics to solve, but I think it has great potential.
Would like to hear your opinion on this.
Thank you.
Enjoy, Dani
