Hi, I plan on making my own flexy bamboo deck…(because O dont like the shape of vanguard)
The problem is, that i need a vacuum pump for a vacuum bagging process…
After some research I havent found any good and afordable in Europe (used), so my first question is do you know any nice place, where I could get one? I have read thomas vacuum pumps are good, but I havent found any in Europe so far, only US
But I have found this:
The owner dosnt know if it can be used for vacuum, he has never used it (inherited) it is a pump for sure…from what I have found it needs oil…and also these specs: type: RV15/11 No (probably number?):12258 220V (voltage probably) 305VA (probably max volts in alternating current) 50Hz (frequency) 1480/min another frequency?! IDK what is this, if it is number of rotations, which would not make sense 1.2 Amps (not sure about this one, the numbers on the motor plate from other photo are not good quality)
Can you tell from these specs if it can be used as vacuum pump? if not is there some way to find it out?
