More questions, no more about the vacuum pump, I bought one from ebay.de for 60 euros, 57" HG
If I sandwitch unidirectional 150g flax between bamboo would it be ok? Would it connect the bamboo veeners together? dont have to use any other glue or resin? (probably dumb one, just making sure)
Is laminating epoxy resin good choice? Flexible epoxy is porbably not am I right?
Epoxy resin is sensitive to UV light, does it mean, that the UV can change properties of the composite or just change the look? How can I prevent that? Is the UV resistant epoxy als ogood choice? any other ways?
Is epoxy/sglass fiber sensitive to acrylic paints (Montana spray cans)? And to alcohol (not that I am some serious alcoholic, but I might be making graphic using alcohol)?
Are you hungry?
THank you for all of your answers
