Hi there! Here is my first post about my board. I have been browsing the forum for 3 years. Now I’ve decided to create an account, cause I cannot find answer to my problem. Recently I’ve finished build of my mountain like longboard (well… some Polish roads are terrible ). This is my second attempt - first one was almost the same (one year ago), but with smaller wheels.
TL;DR: ABS OVER CURRENT error at full throttle, asymmetrical power cables from batteries - is that a problem?
Long story: Yesterday I made a test drive. I was slowly spinning up longboard and when I was at full throttle, the engine stopped (and I fell off the skateboard). It happened only once, since I was afraid of falling again I had something around 24 kmph (15mph).
I connected the VESC to the computer and in the terminal I had only one error:
Fault : FAULT_CODE_ABS_OVER_CURRENT
Current : 148.0
Current filtered : 132.6
Voltage : 29.44
Duty : 0.005
RPM : 27178.5
Tacho : 1053289
Cycles running : 623544
TIM duty : 265
TIM val samp : 132
TIM current samp : 26714
TIM top : 53164
Comm step : 1
Temperature : 53.86
I have tested the motor with multimeter, battery connection, VESC (visual contition) etc. and everything seems fine. In the first build I had exactly the same problem, but in Turnigy 4.10 VESC. After switching to directFET VESC problem still occur. Both VESC’s were send to manufacturer and they passed their tests.
Today I gave another try and the same problem appeared on around 85% of throttle … No DRV errors encountered.
Some ideas: Maybe someone have an idea what is wrong with this build. I suspect the battery problem but I cannot find any information about different lengths of a cables. In my configuration positive one has 38 cm (14.9 inch) AWG10 and negative one has 63 cm (25.6 inch) AWG8. I have spent a lot of time on forum to find similar posts, but most of them were connected with VESC hardware problem.
Another suspect: motor. I tried detection again and at the first time value of BEMF Coupling was around 900, but now measurement is around 760. Problem still occurs.
Setup:
5065 Outruner 270KV (measured 240KV) 1665W in BLDC mode
DirectFET VESC 4.12
8s8p LiIon battery (LG MH1)
Gear ratio 15 / 56 HTD-5M
Pictures of board:
Pictures of VESC Tool:
Thank you for reading this post and I’m counting for your help!
