I’m getting this error more often now, it only happens if I accelerate from a dead stop at 20% of throttle, VESC reboots itself and I don’t have any control from the remote. If I accelerate very smoothly it accelerated with no error.
Can I fix this issue by upgrading the C18 and C26?
post screenshots with your other settings, there might be something else. Nothing wrong with the things you posted. Also did you check your wiring? Might be a small short somewhere.
@kptheinventor - this is what i experienced on my test bench. After sharing my configuration settings, i adjusted the voltages slightly and the abs overcurrent error was resolved. It was something simple like adjusting the voltage up a few volts to not error. When it errored it would lose communication for a second or two and give me 3 red blinks (iirc). After adjustment - no more problem.
Not like the OP who has this when starting from a dead stop - that’s different and more concerning…
I can never get my back to do this error when it’s plugged into my computer. It only happens when I’m physically out riding it. Do you know what settings you adjusted?
I have an exact same setup on a different board but the issue does not happen there, the only difference is on the issue-board I have a 15/36T on 97mm wheels and on the non-issue-board 16/40T on 100mm wheels.
I uploaded the latest @ackmaniac firmware v2.54 yesterday, I’ll test it today and report back.
I don’t think this has anything to do with voltage sag at all. In fact my sag was perfectly normal, my capacity tester has a very high sample rate so that’s why I incorrecrlyt though I was having sag
I’d suggest to use hybrid mode, just a JST connector and solder it to the sensor wires on the motors, you won’t have this issue as manu times as today and a much smoother launch from a dead stop.
