My board and initial set up: 10s LIPO, FOCBOX, SK8 6374 192kv, 15t:36t on 97mm wheels. (single motor)
Initially, I had VESC settings at: Max Motor: 70a Max Batt: 40a ABS Max: 130a.
Things were good - but I wanted to run a larger motor pulley to get some extra speed and less belt slippage.
Now, all settings remain the same, but I changed the gearing to 20t:36t. almost no belt slippage - its great. However, I am getting ABS_OVER_CURRENT errors when applying too much throttle. I am pretty big guy (250lbs), and the gearing feels much less torque focused… Just wondering, am I expecting too much from my single drive board? Am I pushing my FOCBOX too hard, or should it be able to handle this kind of abuse? Before I start digging in to find a problem, I just want to know if there is a problem to find…
Cheers!
