I made this one…
Battery: Samsung 18650 6s6p
Motor: Racestar 5065 140kv
Focbox
It can barely move it self. And a person on it… forget it.
Have I overlooked anything? Shouldn’t it be working? Can I tweek anything in bldc tool to make it work? What might need to be upgraded?
This is full throttle
davidbonde:
140kv
davidbonde:
6s6p
kv to low for the voltage that it’s given that thing won’t go past 5mph that as well motor to small and it’s single drive on pnumatics
louwii
April 27, 2018, 5:42pm
#4
Single 5065? That’s way too small isn’t it?
EDIT: I think @Exiledd_Top found the problem.
I took one motor off my evolve bamboo and it was fine. Took me up pretty steep hills no problem.
that’s a esc vs a vesc, dout it will work out u will burn that evolve motor out
b264
April 27, 2018, 5:52pm
#8
I rode my Carbon GT on one motor while the ESC was half-broken and it also was fine. The performance was extremely underwhelming and you had to run in GT mode, but it worked fine and went up hills. That’s 10S with a single 150kv 5065
I mean that I tested to see if a single motor could run pnumatics by taking the belt of one of the motors on my evolve. Worked fine.
I am thinking the kv here could be the problem ?
b264
April 27, 2018, 5:53pm
#10
We need to see the screen to see if your PPM input is going all the way to 100% as well
So maybe its the 6s thats the problem?
Yup either he needs a higher KV motor or a higher voltage battery.
Also what kind of gearing is he running? It doesn’t look like the motor is even spinning that fast tho for 100% throttle.
Lumaci
April 27, 2018, 5:54pm
#13
140KV and 6S sounds a bit odd, for 6S i would go with something like 270KV
Also 5065 wont give you enough torq to go much faster.
If I were you I would set the erpm limit to 60k and -60k. 100k is fine on better hardware(vesc6).
I will make a video a little later.
Change your motor (to 63xx) and your gearing.
Your battery cutoff is above 6s at full charge
That just means new motor mount as well. Hope I can do something without changing all that. If at all possible
aahhh… will look in to that
