Looks like a bunch of new stuff! I know aliexpress bms vendors sometimes list stuff that’s not actually in production, to see if there’s interest. But at least some of this stuff has sold through and has ratings. This particular vendor is one of the trusted ones at ES.
This first listing is 4s, but has graphs and shows the principle of operation. Looks like energy from high cells goes to low cells.
Dumb versions, I think has LED indicators.
Smart ones, with bluetooth and ability to configure/monitor:
And a new smart bms? Looks bigger, HUGE current (300A only a few bucks more) versions listed. The series count seems all software configured, and has more balance current. No screenshot of app though, might be vaporware?
And this is interesting, looks like a big current drain-down balance board. @Hummie
I’m looking at the 2A active balance board with bluetooth. I think it would work very well with ditching BMS, charging to 90% routinely, and once a month opening up the enclosure to check/balance the pack, and check inspect everything else.
So searching ES came up mostly dry, but youtube has some stuff on the active balancers
It can balance any series count 2s to 24s. Great for me because I have 10s, 12s, 13s, 15s, with maybe 11s coming.
It needs 40v to power itself (last contact on left is the VCC). If your pack has less than 40v like a partially depleted 10s pack, you can wire a dc dc boost inline with battery, or a power supply.
It works just as I thought, and is really perfect for those who have trouble trusting BMS. It looks like a fantastic diagnostic/maintenance tool all around.
I also found some more intensely priced stuff.
Looks like 1s balancers that daisy chain. They sell boards that have many of these hooked up in series (4s, 8s, etc). $82 for the 4s one! 3A balance current. No bluetooth or display, but it looks like high quality stuff used in electric buses and the like. Too much for us IMO.
I’ll probably pull the trigger on the 2A version. I have to find a robust multipin connector (JST XH is not rated for many cycles).
These active balancers are quite an interesting EE problem to design. Those things use a ton of switches to interconnect 2 cells via a DC-DC converter and need to actively compare each cell to select the right ones to balance.
Right so I think you can just bulk charge and the balancing portion will be very very fast without burning off excess as heat. With bluetooth monitoring.
