So I should defiantly add capacitors to this build then? One one my VESC’s came with just one capacitor as well. Is that something I should change?
AFAIK this is only for the VESCs
I know @chrisko used them on his Roxxy build, but yeah, most of what I’m coming up with here are with VESCs.
Just wanna make sure I don’t fry my esc’s. My wires are a lot longer than most of builds I’m seeing on here.
I’m using two Maytech VESC’s and I am looking to go for two cases too, distance will be about 75 cm. Now each of the two Maytech VESC’s already has 3 capacitors each 63V; 680µF. Do you think I will need to install more?
