The only reason Ive seen this is to either have long wires or maybe a higher series number in cell count, but when I opened my ownboard ESC today I only saw two little caps … I was wondering what adding an additional one/two would do
would it give me a little more ability to break when the battery is full? im not sure of how much energy is sent back when breaking in relation to the size of the capacitors
Additional capacitors will only give you a few extra milliseconds of braking
If you had a BMS that could bleed cells (“balance”) at a few amps or more, you could in theory have unlimited braking but this power would be dissipated in the BMS which means it’d get REALLY hot
Most BMS balance at about 50mA or 0.05 A
You’d need a BMS that could balance at like 5 - 10 A
The main reason for the caps on a vesc is to smooth out voltage spikes. On my 12s board I have an extra 6x 3300uf caps to protect the TB vescs I’ve heard of a few failures at 12s and so far so good
