Adding Qi Charging to my GT2B Mod
So I have this Qi Reciever for my phone that I don’t use very often, and I just realized that I can possibly use this to charge my kickass gt2b mod. Pics:
Here is a close up of the connection terminals: Theoretically, if I just soldered the ground and +5v connections to the small lipo in the controller (in parallel) it should be able to charge, correct? I don’t wanna screw up. (also I’m doing this because I uber screwed up the usb charging port and have no way of charging atm) :slight_smile:
Oh yeah I should mention the enclosure is the madmunkey v1 from @FLATLINEcustoms
awesome idea and I think it can work. I want that munkey so bad!
Don’t solder it straight to the lipo inside. It needs to go into a charging circuit then to the battery. So you need to solder the positive and negative to the positive and negative of the USB input in parallel.
there is a tiny BMS attached to the battery, would I be finde soldering to it?
just do it like @seanpain4 suggested. Parallel to the incoming USB wires and you are all set.
@link5505 this is so awesome! Hope it works for you!
@Maxid did you see the MadMunkey thread yet?
Already downloaded and sent to print :slight_smile:
Aw sweet! It works!
Nice work Mason!
now add qi charging to your board!
too inefficient to work :confused:
great idea! This coupled with the battery LED monitor would be great to check battery status at a glance and easily charge it. I’m a huge fan of QI chargers (on several of my phones and tablets).
Nice work!!
I got this coming in the mail, I have a small cutout for the LEDS in the front side so it should be nice and easy :slight_smile:
exactly. only sucky part is $5 shipping for a 2.50 item.
yeah but oh well :confused:
ok so none of this really works after all. The 4 LED battery indicator didn’t work from the get go, and I’ve had this controller on the charging pad for a week now and it still isn’t fully charged. In fact, I think it just died! Whenever I put the controller on the pad I get LEDs on to indicate that I am charging, but whenever I take it off, it won’t turn on. I have the controller super glued together, so taking this apart will not be fun.
Any suggestions? I have microusb connectors lying around somewhere, but I’m not 100% sure where the positive and negative pins are.
If you have one connected, can’t you use a multimeter to find the +/- pins? Maybe desolder it first.
quick google search:
You are sure that selling high-energy custom batteries is a good idea? :wink:
This guy is a savage :joy:
