First time Building an electric skateboard, so I would like to know what could be changed with the list below… Here is my parts list.
Single motor mechanical kit diy-el … nical-kit/ (For ease of assembly. I don’t want to scavenge around for the rights parts.) 6364-213kv motor https://hobbyking.com/en_us/turnigy-aer … motor.html (I believe I want to get a higher kv rated motor probably 260.) VESC speed controller diy-el … board-esc/ (I don’t know if this is the best VESC for servo connector for VESC diy-el … connector/ 2.4 ghz remote diy-el … ontroller/ 6s 25c LiPo battery https://hobbyking.com/en_us/zippy-compa … -pack.html (This battery doesn’t have a BMS, so I will not be getting now)
My first question is with the battery: The one I chose doesn’t have a BMS, so I would like to get a good battery with a BMS that will work well with the motor I get. My second question is with the motor: should I get a 260 kv motor. I need it for semi-steep hills. If I do Imagine Ill need a different battery probably 8s.
Besides that, any modifications or tips would be appreciated
