I will start by listing my wants, but keep in mind, I’m not sure if I know what I want when it comes to electronics…
Budget is 1500-2000$
MAX 30 MPH speed, and MINIMUM 30 miles range.
Wanting to use my already owned stiff 7 ply maple board, (unless it’s not Ideal…)
All Terrain wheels
good suspension
VESC instead of ESC (smoother accelerate, and decelerate)
180/190/200 kv Sensored motors + VESC for smoother accelerating and decelerating.
Dual Belt driven sensored motors.
Molicel p42A batteries unless there is same quality but more quantity option (quality > quantity)
I want the possibility to connect two remote controllers. (one with limit of 12 MPH, and the other with limit 24-30 MPH) instead of one controller with multiple speed options, (but I don’t know how…)
Questions:
What kind of belt drive dimensions should I use, considering trucks, wheel diameter, and key mounts? I would prefer wheels to be 120mm or even more…
What suspension and trucks should I use? (I want to go offroad).
Batteries minimum 10s5p (4000-4200mah) / (720W-756W)
Vesc + Sensored motors for smooth accelerating, and decelerating, something more I need for smooth speed-transmission?
Two controllers with different speed limits = Dual PPM receiver, something else?
High discharge BMS and «laptop» charger + anti spark switch, is enough? Is anti spark switch safest? (I want over current protection)
Is it possible with All terrain wheels without Bearings? (would be nice with no rusty bearings) (or willl no bearings result in instant stop, no rolling when I release the accelerator?)…
How to make the board IP67, or atleast IP66 resistant?
Which type of bindings for foot is best?
- Ratchet bindings
- Camlock bindings
- Hook bindings
- Luxury-hook bindings
- Heel straps
What else do I need to make my own DIY ESK8 board? Thank you in advance for taking time and guiding a noob!!
