Hi e-riders !
After some builds ( the Alienboard(1th esk8, named e-longboard here…), the Darth Vapor (e-MTB) and La Bonita (2nd esk8), I make a simple one to could ride this summer, but want to continue my prototyping beside on it and an other board I will present soon.
Deck - perso DIY 36" (1th time a 38" then adjut for my feels) Mount - ADS single DIY Kit motor 63mm 15x32T (I will pass in 15mm drive soon) Motor - Alien new 6374 HEV 170kv 3.3kw (maybe a GTX 3kW 200kv soon) ESC - VESC Truck - Caliber bushing Venom SHR (Ronin are waiting to the ring mount adaptator) Wheels - Alien Power wheel 83mm 78A (Flywheels 83mm to trie again soon) Battery - 10s5Ah20c (from Bonita, charge with extern BMS !) Radio - Alien Power System 2.4Ghz Remote control (actualy GT2B Custom Design by OKP) And custom fiber / resin case will follow from the unwrapped deck.(only 20mm)
Now pictures say more than me :
or the vid of the 1th part to the 1th ride
https://youtu.be/CLu1X7sTFm0
Alien parts
The custom deck (9 plies) cut ends !!The layout (long and slim battery pack I hope around 16/17mm) :
I resized and adjusted the symmetry of the deck easing of some 100g and familiarized myself with the trimmer.
Then I went to dig the deck of the center
And here the profile of ply
now the enclosure :
I wanted to change a little technique and tape the mold directly on the deck (wrapped in cellophane)
less tape to be applied but equally complicated :roll:
Longhairedboy style like Whitepony suggest me a big thank you for this !!
insert in place and enclosure ends !
extension in placeTADA !!!
Now I have to ride !!!
hope you enjoy it ! More info >>> here, stay tune, more to comes…
After some times riding, I made some modifications
tracing, fitting, cutting, sanding, varnish below :ugeek: ‘’
Result now is a 36" ! (always the same wheelbase )I took the opportunity of all this work to cut my engine cover (you cas see the made > here, little sanding and shot matt varnish.
The support … (almost done: roll: Now that the cache is finished it will help for quotation centering etc )
After that, a little ride in Paris …
https://monlongboardelectrique.files.wordpress.com/2016/09/image29.jpeg
During the time to finish the motor cage, I have some other mod to make to the build again !.. But somes arts are waiting :
https://monlongboardelectrique.files.wordpress.com/2016/09/dsc_0116l.jpg
https://monlongboardelectrique.files.wordpress.com/2016/09/dsc_0146l.jpg
https://monlongboardelectrique.files.wordpress.com/2016/09/dsc_0471l.jpg
ENJOY & GOOD RiDE !
