Sometimes it gives this message. Simply start the wizard again.
The Motor Wizard is quite simple now and minimises questions noobs can’t answer. It’s pretty much an autopilot.
Standard is FOC nowadays, but HW4.12 can get damaged if quality is low and if you use funny settings or non ideal motors. So you have to FOC it manually.
yes I understand that and let me just say, the new tool is SOOOOOOOOOOOOOOO much simpler than the old one. auto connect, firmware update, motor config wizard, input wizard. Boom, done. I like it, good for noobs as you say. It does however set outrageous current settings, which is not noob friendly! 99A/ -99A on a 10S battery is not good
So does the RT logging work now? I could not get it to work in the last version.
Also the mobile tool shows a lot of potential, I like what I see here, with telemetry logging and some tidying up (and that ability to have miles instead of kilometers) and its going to be amazing.
Battery Amps are not so important. For regen you have an Amp limiter built into your thumb and for drain the motor amps are the limiting factor.
Motor power and battery capabilities should match anyway.
Sort of useless to strap a 6380 to a 10S2P pack.
Exactly my thoughts I really appreciate what Ben did when he designed the VESC and is still doing with the Firmware and the Tools BUT I think everything is getting more and more trampa-centered, just like trampa is a puppetmaster or, as I previously was joking, Lord Vetinari.
@trampa You might use overpowered Lipos in your Boards but most of us don’t and battery max and min are quite important for us. I for myself know what I’m doing but the new Tool makes it easier for noobs to make bad mistakes. They might even be happy about the wrong settings at first since you get more power, but eg. someone uses dual motors that are capable of 40A according the new detection and has a battery that can do 30A max leads to things go badly wrong. You should care too since you try so hard to bind the VESC™ to trampa™.
Hey man. How are your Focboxes running with the new vesc software? I’m running ackamaniac on dual flipsky 6374s for. My
And it is running ok. My remote was acting a little funny so I’m thinking of reflashing But I’m also thinking of putting the latest vesc firmware on there.
Fine. I have done all the fw upgrades with no problems. Metr now works with the new fw.
If you want to reach me go to forum. since I don’t frequent here any more.
hey guys maybe this isnt the right place, but how do i get my vescs (hw 6, ESCapes) to connect via can? i thought the vesc too had an option to select slave or master vesc in the ppm setup wizard but the new vesc tool i downloaded isnt opting me to do that (even older videos that use vesc tool have the pop up, mine doesnt get it)
Really nice. Downloaded VESC tool mobile app and connected to my board - Dual Focboxes 4.12 - via Bluetooth. Everything worked fine. Running the newest Firmware now and the app shows everything to me. Also changing profiles now and seeing realtime data is everything I need and did before with metr app.
I really like the info about the driven kilometers of the current trip.
Does anybody know if the VESC (Focboxes or whatever) saves the kilometer (mileage) overall? From the beginning since turned on the first time? I would like to have an odometer about my km/miles altogether, since riding. … I always liked it in the Boosted or Onewheel app (never had one of these boards), so it would be nice to know how “old” my board is.
If the info is somewhere in the VESC then it should be easy to read it out. Thanks. And keep up the good work, Benjamin.
The VESC itself does not save the overall kilometer because it resets until reboot. Because you say you are also using Metr app. There you can click on your module in the Realtime tab and see all time stats and todays stats.
I know this in metr app but it also starts from 0 every time, also in the All Time tab.
I thinks its true, the ESC resets on every reboot. … A solution would be that the software (app) stores and adds everything together (all trips = km of all time).
No, the “All Time” tab should not reset and does exactly what you are saying, it adds everything together.
If it is not working like it should, make sure you are running the latest Metr app version and Metr Pro firmware version. If you still have problems please send us a mail with the log file to [email protected] and we will figure it out.
You are right. My last trip 2 days ago is now the total value in All Time tab. So it saved it. But before it was always 0. I’m sure I checked it a few times. Nevertheless, it works from now on. … Thank you also for the tip with the firmware. Had 3.63 on it (saved the last trip anyways) and now I updated to 3.69
Anyone downgraded to 3.57 from Ackmaniac and noticed horrible throttle response? Prolly some kind of setting that is not correct but I the only thing I could find in app pwm setting that could create a long delay was the median filter and I tried disabling that without having a impact. I use the “micro” style remote in this picture and it’s configured as pwm. Works fine on ackmaniac but on 3.57 vesc fw it keeps throttle on for what feels like a second and it also lags getting throttle on. Feels horrible when the board accelerates when I’m hitting the brakes trying to stop it
