All Terrain Dual Rear Kit 15mm belts
Up for sale now is an All Terrain Dual Rear Kit! I never got to try this kit, so really don’t know how good it is. It feels solid though! I sold one of these on here already and was keeping one for myself, but simply not enough time for another build with a young baby now.
Comes with the following:
Front and Rear Trucks 4 all terrain wheels (8" wheels.) 2 motor mounts 2 drive wheel pulleys (15mm not sure, didn’t want to count how many teeth) 2 motor pulleys (15mm 15T) 2 belts (15mm wide) I believe the diagonal measurement for the motor mount is 30mm approximately.
think it might be missing a nut and bolt to bolt the motor mounts to the trucks, but can be found at your local hardware store easily.
Looking for $200 USD Shipped to USA and Canada.
PM me if you’re interested!
Bump! Need to clear some space.
Isn’t this just @diyeboard stuff?
Don’t think so, unless they are using the same supplier as me, But this didn’t come from them
Mmm tempting
@johnny_261 got a deck to suit you wanna part with?
No I don’t unfortunately, never got that far in this build plan to buy a deck…
Want this but also the focbox :confused:
Hey @Eboosted can you tell if this will work on the trampa carver deck?
Yes they should work, they look like Ultimate Trampa copycats, but I suggest you use the carve base plates in order to be able to use the inner spring position
