Janux Dual* drive motor mounts for AT/eMTB. CNC machined from aluminum T6061 alloy. A truly universal and versatile motor mount system for MBS Matrix Pro, MBS Matrix II Pro, Trampa MTB Spring trucks, and Trampa Carve trucks.
For a complete line of my products, please visit Janux-esk8.com
Features:
Adjustable angle adapter ±15º rotational swing
Laterally adjustable (+10mm) arm with Adjustable Belt Tensioning Idler forcing belt & teeth to interlock perfect with the motor pulley to prevent from tooth skipping, improve braking, and to gain maximum torque on power at the wheels
Motor housing with stabilizing crossbars
Universal motor mount X-bracket to fit any 50xx and 63xx motors.
*****Optional second idler assembly ($10 each)
Janux motor mount system is $170, includes the following:
Motor mounts x 2 (specify adapter)
Idler assembly x 2 (additional idler assembly available for $10 each)
Are you planning to make different clamps for other mountain board trucks? Like Matrix II or old Matrix with brake mount protrusion for example? And what’s it cost to ship within cali?
Janux Dual drive motor mounts for AT/eMTB. CNC machined from aluminum T6061 alloy. A truly universal and versatile motor mount system for MBS Matrix Pro, MBS Matrix II Pro, Trampa MTB Spring trucks, and Trampa Carve trucks.
Will post additional pictures of MBS Matrix shortly. Shipping within US is $8.
That’s great. The crossbars would need adjusting as well because I think the mounts would need to sit closer together to allow alignment on 20mm belts.
