Does the Trampa truck hanger need to be milled?
No adapters are engineered to fit specific trucks, no need to mill or file hanger.
Do you have access to Trampa Trucks as well would like to order both and minimize shipping costsā¦
I only have enough, one of each, tor prototyping adapters.
I would like to know if you have your produkt in stock?
What are you looking for?
Never mind, I was debating between your product and someone elses and went with other choice. Your motor mounts are reeeely cool loking, unfortunately Iām already over budget
do the springs in the trucks provide any vibration dampening or are they just for turning?
Trampa Street Carver (Vertigo Mini)
Dual 6374s
Can I buy just the piece that clamps to the hanger. Unfortunately I got the wrong one when I picked up mounts from you a couple weeks ago @marcmt88
Please see PM
Available adapters:
Janux motor mount for MBS Matrix Pro II
I will be purchasing this from you soon. Iām just starting my research for a new build (Built my commuter almost 2 years ago now). Deciding between trampa and MBS trucks, preference?
Canāt go wrong with either MBS Matrix Pro or Trampa Vertigo Spring. For more detail pictures go to my Janux-esk8.com
the Janux dual Motor mount would work for MBS Matrix truck ( its the original MBS Comp95 truck) there is no pro or II written on the truck. I wanna run chain, 14 T motor 72 T wheel. It seems center to center around between 4- 5 inch ( 10 to 12 cm) . would the mount work?
Pro version has the springs as shock absorbers, Pro II is lighter with Eggshock dampers. I designed these mounts to be belt driven. Canāt confirm whether chain setup would work.
My matrix truck should work with the matrix Pro mount, I also can modify . Could you do me a favour before I place my order on the Janux webpage - could you measure for me the distance from motor mount center to truck axle center ? I checked the Janux page but couldnāt find any details, thanks a lot
My mount can be adjustable from 107-118mm center of truck axle to center of motor mount. I also have an āAnodized black and maroonā version that is not shown on my website. Iāll post a picture shortly.
Great, Thanks a lot for measuring . The Mount will definitely work for me than. Curious about your pictures. Looking forward to place my order- either way the anodized one or silver Aluminium . Thanks.
Adapters for Trampa Spring, Trampa Street Carver, MBS Pro, and MBS Pro II
Anodized black with Maroon finish motor bracket
Mount installed on MBS Matrix Pro II
