Finally, after six months of development, I accomplished the build of the aluminum frame.
No more wooden decks, no more outer boxes, no more improvised skateboard.
The whole frame is made of aluminum and covered by CNC carbon fiber for strength/weight and temperature matters.
Very low center of gravity, essential for high speeds and cruising.
All tests are done, stiff as hell.
Can hold up to 200kg of force
All is assembled and working FANTASTIC!
Now for my question.
As a global community,
Will you be interested of purchasing from a store a set of frame?
I have a black fiber carbon frame and it get very hot under direct sun…probably wuch warmer than with shiny aluminium…
Another problem is dissipating the heat from esc and again aluminium is supposed to be better than carbon fiber.
